How to anotaye spot elevation of patio in the roof ? Please help
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
386 Aufrufe, 5 Antworten
Hi
I have patio at level 2
I want in the roof plan to put spot elevation of the patio
But it doesnt give me (circle with cros)
Thank you
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Only when i put bottom unlimitted in view range it works...
Is it only this way?
Nachricht 3 von 6
cbcarch
Try using a Plan Region. You can set View Range to whatever you need, just over the Patio portion in your Roof Plan.
View Tab>Plan Views>Plan Region ( In your Roof Plan View, Make sure Plan Regions are turned on in VG> Annotation Categories )
Sketch a rectangle where you need around Patio.
Then set View Range / cut plane.
Place Spot Elevation in the view.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 4 von 6
chrisplyler
Well, it does not have to be "unlimited," but it does have to be low enough that you can touch the upper surface of the patio.
Nachricht 5 von 6
als Antwort auf: chrisplyler
...or use the default "Site" plan. At 200 feet above Level 1, you'll likely see everything. Smiley (zwinkernd)
Nachricht 6 von 6
Region plan view is exactly what i needed
Thanks!!!
