How to ammend apparent misplaced sweep on generic 9" concrete wall
4 ANTWORTEN 4
Nachricht 1 von 5
327 Aufrufe, 4 Antworten
One of the exterior tilt up 9 inches walls of an existing building that I am drawing has what appears a misplaced sweep at one location above the third floor.  The side with the notch is on the exterior so I am trying to see how could I repair that.  See Attached PDF with the wall and the area of the horizontal opening clouded in red.
The wall is near the same area where I added some copings on the top of the adjacent perpendicular wall, so I believe one of these sweeps erroneously went down and attached to that wall and caused the undesired opening.
I have tried to modify the wall, editing the profile, then deleting and creating a similar new wall, etc, but I get errors since it also appears that some of the other nearby elements are attached to it and the program ask me to delete these other things, that I do not want to do.
Question:  What is this notch on the wall?  How could I close and repair the generic wall without hurting the wall and its surroundings?
Thanks in advance.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Looks like a Reveal to me.  Can you TAB-Select it?
You can ZIP and post the file if you want.
Nachricht 3 von 5
als Antwort auf: barthbradley
When I click it, I get the wall and using tab to see if I get something there I do not get anything, only the entire wall.  I suspect the notch was caused when I was adding the copings' sweeps on the adjacent perpendicular wall, that is, maybe one of the copings jumped to that wall at that location.  What do you think?
Is there a way to join that notch without having to delete and redraw the wall?
Nachricht 4 von 5
Is the Reveal built into the Wall Type?  Check and see.
Can you just post the file. It would be so much faster and easier than guessing.
Nachricht 5 von 5
It was a 'hidden sweep" indeed.  I brought the wall down (stretched it down) using a wall section, and in the process it directed me to a view that had the hidden sweep a little inside the building, and it was in a different color for easy viewing, and I was able to delete it right there (the dialog asked me to delete it to continue, so that is what I did...I think that is what I did then).  Now the notch has disappeared completely.
Thanks for your feedback.
