How to align text in level markers/symbols?
0 ANTWORTEN 0
Nachricht 1 von 1
Andy_Grout
144 Aufrufe, 0 Antworten
I have a project in which we wish to position the level markers on the left-hand side of the drawings. Unfortunately we're running into an issue where the level name does not align across different level markers making the drawings look quite messy.
We want the text to be the standard left-aligned format. I've set up a test family with two sets of 'level name' labels on either side of the central reference line:
When this is used in a project environment, the labels align correctly on the right-hand level markers, but on the left-hand markers the bottom level name text is indented compared to the level above:
Level Marker Text Alignment Issue.JPG It is as if the text is left aligned, but it is being positioned to the right-side of the text box depending on the length of the text. If I add in a long row of 'X's to each level name, then the labels become aligned because the longest 'word' is the same length in each label:
If anyone has a solution to this, I'd really appreciate the help
0 ANTWORTEN 0
