How to Align in Autodesk360
Instructions Appreciated...
LisaDrago
Hello @Anonymous and Welcome to the community!
If I may ask - can you give a bit more information on what exactly you are trying to do?
What are you trying to align? What software are you using?
The more inforamtion and even images you can provide will help us help you.
Again - Welcome to the community.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
RDAOU
Hmmmm...I am assuming that your models when merged in BIM360 Glue came out all mis-aligned
First is to check the Transform option for each has same set of co-ordinates for x,y,z etc / rotation/scale (If you are not sure how to do so...The Transform tools are used to align the individual models in a merged model. However, you can only use the Transform tools (coordinates, units) for one model at a time. The transformation applies only to the specific merged model. It is a one-time process. As the individual models of a merged model are updated, the transformations are applied.
  1. Open a merged model.
  2. In the BIM 360 toolbar, click Models.
  3. Select  models. (Showing and hiding can help isolate models in the view.)
  4. In the Models module, select a reference model and click  Transform.
  5. Set the coordinates of the reference model. (ie: enter X, Y, and Z coordinate values in Origin, Rotate, Scale and click Save.If you are aligning a model to another that has shared coordinates, simply copy and paste the coordinates.)
  6. If necessary, adjust the units of measure. To do so select the model and click Adjust units then Specify units
  7. click Ok.
PS: If you are using Revit 2015 or earlier you might need to update your BIM 360 Glue Add-in
More details on what you are experiencing and/or any error or prompt msgs might help in giving a better clarification
Source: Autedesk Knowledge Network
If a line is in 70 degree
I have to Align my drawing to the line connecting two points of the line...
