Hello, I'm very new to Revit and started using it last week. I need help modeling a bathroom underneath a staircase. I saw many video tutorials about editing profiles, but its not quite what I was needing.
I need to cut the tops of these two walls along the slope of the staircase, but with edit profiles, I can only manage to adjust the front face, not the sides of my wall. I'm using Revit 2024 Windows 64-bit.
Solved by ralphdenhaan. Go to Solution.
I hope the print screen below can help you out:
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
I dont have that reference plane option and when I type RP nothing happens.
Create a section view, then you can place the Ref Plane.
I did make a section but dont see the option to Reference Plane. When I try another command like Pick a Plane it selects the entire staircase not just the one slope.
I tried doing that as well but I was getting an orange error message about that floor intersecting with my other floors.
In your screenshot, you are using a 3D view but try a section instead.
I wouldn't create a floor for the stair slope. You can edit profile the wall, or place a ref plane under the stair matching the slope and attach top of wall to it.
@ToanDN , Good advice, just as @ralphdenhaan suggested.
I guess I'm too used to working with architects that want curved stair runs:
Reference planes and Edit profile options go out the window then 🙂
-G
