I am bearing the roof joists on a sloped beam on one side (for sloping down to the drain) and the other side of the joists is a the same level. At this point I am adding each of the open web joists individually one by one (amateurish knowledge, so I am doing each one by one). The side that do not slope is OK since the end of the joists are at the same level, but the bearing height of each of the joists on the other side vary each one by one.
Question: is there a command (or a way?) that will let me select the sloped beam and pick all the joists on that side all at one time so they all bear at the different heights of the sloped beam?
