How to Add Railings in An Opening of Irregular Shape
hliS658H
Message 1 of 12
hliS658H
How to add railings to an irregular opening?
Replies (11)
Message 2 of 12
Use a curtain wall and edit profile.
Message 3 of 12
Not sure what you mean by "irregular shape/opening".   Looks pretty conventional to me.  Are you meaning that there is no host for the Railing? If so, why not create a "reference" host and hide it in the View?
...this might be of interest to you as well:
https://www.youtube.com/watch?v=YkNg6MC4S18
Message 4 of 12
hliS658H
But I don't see there is an option of railing for curtain panel. Railing is different system family. It seems not to allow me to edit the family.
Message 5 of 12
Create a curtain wall type that is the same as your railing type using mullions as rails and balusters.
Message 6 of 12
hliS658H
Different railing height
Message 7 of 12
If you want to use Railing then it can be done as well. Just edit the path, select a segment and change its Height Correction.
Message 8 of 12
hliS658H
The highlighted two parts will be hard to use height correction.  Otherwise this is a good way to model it. Curtain wall method is more straightforward. I am able to make it. Thank you!
Message 9 of 12
hliS658H
Is there a way to add top and base like this?  I tried to add Horizontal Mullion, it was just horizontal and not following the profile.
Message 10 of 12
Yes.  Horizontal Border Mullions should work.
Message 11 of 12
hliS658H
Very strange thing happens - the horizontal border has been separated to small segments by the railings, but the border looks fine along the slope.
Message 12 of 12
