How to add parameters to a room tag?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
AidanHawkins
610 Aufrufe, 4 Antworten
I have set up project parameters for my rooms in Revit
They are named ´Occupant 1´ and ´Occupant 2´
I can not add them to my room tag as they do not allow me
Do I need to change them so it gives me the option to add them when I edit the room tags family
Regards
Aidan
4 ANTWORTEN 4
Nachricht 2 von 5
rxi.gg
als Antwort auf: AidanHawkins
Make that parameters shared parameters
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Nachricht 3 von 5
- Create them as shared parameters
- Add them as labels in the tag family
- Add them to project parameters and assign to Rooms category
Nachricht 4 von 5
AidanHawkins
als Antwort auf: ToanDN
Are these 3 different methods or are they the steps I should take
Aidan
Nachricht 5 von 5
Aidan
They are steps.
