hi can i add my youtube revit video tutorials link here?
Title renamed for clarity by @Viveka_CD
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Gelöst von markcalloway. Gehe zur Lösung
Hi @nasirm04
Click on your profile at the top of the screen when you are signed in, go to My Dashboard, then on the webpage select contributions. There is a button on the right of the page now to add contributions, I believe it is a link you are wanting to add. Then just follow the on screen instructions.
Hi @nasirm04
I see that you are a new visitor! Welcome to the Autodesk community! ![]()
Please see similar thread Embedding An Image & Other Helpful Posting Tips
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
