Hello, I need help on how to edit a chandelier family. It has just a light source, my question is can I possibly add more light sources to the candles? If yes, I will like a guide on how to do that. Thanks
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Sure. See this...
Also, check with chandelier manufacturers for Revit content. Perhaps a single IES file for a single light source would suffice.
I've looked at this link several times, but I don't understand how to import multiple sources into a luminaire template, as I am not able to delete the original light source.
Does chandeliers with multiple light sources have to be created from a generic template?
Did that solve this thread? You ready to model Liberace's piano candelabra now? ![]()
... as @barthbradley said:
... here is your chandelier (attached .rfa)
.... downloaded from revitcity.com
... just take a look on how was made
....(you can do some reverse engineering)
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Hi. Yes, your link above did solve my problem thanks. Couldn't figure out how to mark the thread solved other than liking your post...
