How to add multiple comments to a room tag
FG_RVT
FG_RVT
Propably easy to do but i can't figure this out somehow.
I want to create a room tag with two comments. I've created a room tag family and have and added the comment parameter and this works as intended. The second comment is not working though and honestly i am still figuring it out how shared parameters etc. work exactly.
I created a shared parameter called Comment2 and added that to my annotation but it's not editable when i load the family into my project. What do i need to do so i can edit this one too just as i do with the standard comment?
RDAOU
@FG_RVT  In the model, you need to add the same shared parameter to the Rooms Category also
FG_RVT
@RDAOUThanks, that worked. Just added the shared parameter to the projectparameters in the rooms category and it works like a charm now. Knew it would be an easy fix but sometimes it's just not quite the most intuitive process for a newbie
