Hi Viveka and community
Can anyone tell me how to add labels to components so when printed it can be seen
Are you trying to add labels to the component family? What exactly are you trying to achieve?
Since I don';t know what exactly it is that you are trying to do, one of the two should work -
In the family -
1) Create a label
2) Nest a generic annotation family
3) Sometimes the simplest approach is the most effective - just create a piece of 'dumb' text
Hi @Anonymous
I see that you are a new visitor! Welcome to the Autodesk community! ![]()
As @Sahay_R mentioned you can try nesting generic annotation families inside host model families so that the annotations appear in the model.
This is useful if you want to include a label with a model family and display that label in the project, which I assume is what you are seeking.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
