- Mute
- Permalink
- Report
Hi, I'm using Revit 2015 this is my issue:
I know that if you add normal text in a detail item, the text won't appear in the project. So I created a generic annotation by instance and add it in the detail item. But, I need to add leaders ( Arrows ) to specify some equipement in the detail. When I select the generic annotation and click on Edit type
it show me a graphic option to choose the "leader tick mark"(see the pitcure) BUT I can't add a leader in the modify/text note -> format (see also the picture).
edit type
when i select a "normal text"
Also, when i select the generic annotation, the format option does'nt appear ...
So, is it possible to add a leader from a generic annotation in a detail item template family?
thanks in advance for your answers.
