how to add a family parameter that can be shown in schedules and tags
AidanHawkins
Message 1 of 14
AidanHawkins
how to add a family parameter that can be shown in schedules and tags?
Or is this possible
Aidan
Replies (13)
Message 2 of 14
Shared Parameter. Use the exact same Shared Parameter in Tag that is used in Family. Shared Parameters can also be brought into Project Schedules.
If it's a text parameter, you could always re-purpose one of the in-built parameters, such as comments or description.
Message 3 of 14
Add shared parameters to the family and to the tag family as labels.
Message 4 of 14
AidanHawkins
I have 100s of doors in my project
I want to create a parameter for my doors that is a Yes/No parameter that yes means it has a lock and no means it doesnt have a lock
How can I do this? As I cant change for each one when I do it this method
Message 5 of 14
Shared Parameter as Project Parameter assigned to Door Category.  That work?
Message 6 of 14
AidanHawkins
I created a shared parameter.. But can only create a shared parameter under the category of door.
Is that okay?
Then i created a project parameter in the project and grouped it under identity data
And then gave it the door catagory
But I cant see it in the identity data of the doors?
Regards
Aidan
Message 7 of 14
AidanHawkins
Is that okay?
And then gave it the door category
But I can't see it in the identity data of the doors?
Do I need to create a global parameter?
Regards
Aidan
Message 8 of 14
AidanHawkins
Is that okay?
Regards
Aidan
Message 9 of 14
If you add the parameter as a type parameter then you need to edit door type to see it.  If you add it as an instance parameter then you select a door and see it.  For the hardware yes no parameter, I think you can add it as an instance parameter.
Message 10 of 14
AidanHawkins
 I did that and still can´t see it in my identity data for my doors , it doesnt appear
Message 11 of 14
So, what is the solution?  Project Parameter like I suggested to you and @ToanDN?
Message 12 of 14
@AidanHawkins : Can you mark Message #5 as the Accepted Solution?
Thank you. You're Welcome.
Message 13 of 14
Now select a door in a view and look at its properties palette under Identity Data section.
Message 14 of 14
Create a Door Schedule and add the Yes/No Shared/Project Parameter to it. Then go through and activate all the Yes/No Parameters. They are initially NULL, meaning they are neither Yes or No.
