How the line type of "Callout" rectangle is changed?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
octavio2
1034 Aufrufe, 4 Antworten
The out of the box rectangle created by the "Callout" to show a plan detail has a very weak thin line.  In AutoCAD we would prefer a thicker dashed line and is easy to change.
In Revit, how to change the line type and weight of that "Callout" rectangle to a desired personal preference?
Thanks in advance.
4 ANTWORTEN 4
Nachricht 2 von 5
L.Maas
als Antwort auf: octavio2
Change the Object Style of the Callout in your view(s)
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 5
_Vijay
If want to change inside in Revit chenge like @L.Maas . Or if need in only exported autocad you can change while export in the export settings.
Nachricht 4 von 5
ennujozlagam
to follow up just type TL in your keyboard to see the actual thickness of your lines. thanks
Nachricht 5 von 5
octavio2
als Antwort auf: L.Maas
Thanks Louis for your direction.  I used "Dash-Tight" with "7 Line Weight", and both the Callout Boundary and its Leader Line look much better now.
