How materialize an Exterior Wall
jochia13
jochia13
I want to create an exterior wall with siding Clapboard and Gypsum Wall Board. Can you give me an example of how a exterior wall is materialize. Like what can be used in between the siding and the Gyp.
Not clear on your question.  Are you asking how to INSERT wall layers?
Corsten.Au
Hi
Try to Study existing wall types in sample revit files..
There are different material depending on the Wall-Structure
1. Finish
2. Structure
3. Substrate
4. Thermal / Air later
5. Finish
6. membrane
and depending on EXTERIOR SIDE and INTERIOR SIDE of the wall, assign required Function, material, thickness and wraps...
Material will show up depending on the view graphics display options,
coarse , medium and fine for Cut plans, cut sections of material..
Corsten
Building Designer
ennujozlagam
hello, you can refer to this wall properties. thanks
