how many licenses
1 ANTWORT 1
Nachricht 1 von 2
231 Aufrufe, 1 Antwort
how many licenses
According to the report below is this using one license or two network licenses? running revit and navisworks.
  Autodesk Building Design Suite Ultimate 2017: 1 license  1 in use.
xxx@xxx
Checked out license at 19-May-17 4:35 PM
Hours used: 90:02
Autodesk Building Design Suite Ultimate 2018: 1 license  0 in use.
Autodesk Building Design Suite Ultimate Package: 1 license  1 in use.
xxx@xxx
Hours used: 90:02
thank you!
1 ANTWORT 1
Nachricht 2 von 2
dzanta
als Antwort auf: Anonymous
the LMTools states you are using 1 license from the BDSU 2017 package.  A package increment allows for prior version usage.
You have BDSU 2018 and are allowed to use 2018 and 3 prior versions.  Since it states BDSU 2018 has 1 seat available and none in use, it is using the package increment to allow for BDSU 2017 usage...hence 1 license in use.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
