Message 1 of 14
Does anyone have any insight into how this default component is made? I am puzzled as to how the two lines in the center are connected to the corners of the filled region. All I can find is there is a Linear Dimension constraint applied to them:
But nothing is displayed on the drawing. Using the Reveal Constraints tool also shows nothing.
If you make new type for this family you can modify the length and width of the cut lumber section and the two crossing lines move with the rectangular filled region, ie the two crossing lines always have their endpoints in the corners of the filled region. It is this behavior I would like to understand.
Any ideas?
