How I would add a project base point and survey point to my site plan view?
11 ANTWORTEN 11
Nachricht 1 von 12
704 Aufrufe, 11 Antworten
How I would add a project base point and survey point to my site plan view? I've deleted my site plan view accidently and tried to create a new one but no base point shows on it
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: Anonymous
VV > Site > click on the + and tick Project Base point and Survey point boxes.
Nachricht 3 von 12
als Antwort auf: ToanDN
I  accidentally deleted the site plan and I created new floor plan from view templates and renamed it site plan. I don't see any + and tick for project base point
Nachricht 4 von 12
Did you type VV to open the table?
Nachricht 5 von 12
I pressed w and nothing happened but however I got back the project base point. But the elevation markers are hidden and I am not able to unhide them . Is it because I have Revit LT?
Nachricht 6 von 12
The visibility graphics are all greyed out and I cant edit them
Nachricht 7 von 12
Back out and change the view template of the View's properties to Site Plan (this template may turn on Project Base point and Survey Point already so you don;t need to do anything further), or None if you can't find Site Plan then do the VV above.
Nachricht 8 von 12
not W, VV or VG
Nachricht 9 von 12
s.borello
VV or VG... visibility graphics.
Nachricht 10 von 12
Might be easier to just press Reveal Hidden Elements (light-bulb on View Control Bar), select the PBP and SP (shown red) and press Unhide Category on the Contextual Tab.
Nachricht 11 von 12
als Antwort auf: barthbradley
Why I cant place a topography surface on a site plan that I've create it? I've create a site plan but now I'm not able to create a topography surface when trying place it's points.
Nachricht 12 von 12
This is unrelated to the Visibility State of the Survey Point and Project Base Point, if that is what you are thinking.  Did you find a solution to your origin question: "How I would add a project base point and survey point to my site plan view"? Let's stick with one topic per thread.
