The COBie Extension page on the BIM Interoperability Tools site has sample Revit models you can download and review. I’d recommend starting there. Data format and needs may not match your specific requirements but it’s a start.
https://interoperability.autodesk.com/cobieextensionrevit.php
Thanks for your answers ,but I have filled in a lot of information (contacts , zones...)that I have reviwed before , but when I fill in the information here via assign , it is not reflected in the table . How should I fill in the information ?
The COBie Extension only fills in some of the parameters. Most can be identified by reviewing the rows in the table when you click the Update button.
COBie Extension for Revit - Update | Revit | Autodesk Knowledge Network
Other parameters need to be filled in by you manually. If you look at them, they are things like "Serial Number", and "Warranty Date". There is no way the software would know that. That's why they are manually entered.
Many thanks , this explanation has been very englightening for me . I wrote the information manually . but I worked with curtain wall . I have defined the single type family in many places in different sizes. Is there a solution where the area , length and width measurements can be reflected automatically as in the image ?
If the data already exists in other parameters, you might be able to use the Parameter Mapping function.
COBie Extension for Revit - Parameter Mappings - YouTube
Some things to watch out for:
If this limitation makes it impossible to use the Parameter Mapping, I am sure you can find some kind of Dynamo script that can target and copy the specific data you need to the COBie parameters. I do not have anything like that, but I have seen others use similar solutions.
