How have you been setting up 2nd floor plan view w/ level below?
EmptySaturnV
EmptySaturnV
I'd like to hear how some of you have been handling the view of your floor plans when the habitable space of a level does not encompass the entire area of a level. For example, I have attached a plan I am blocking out at the moment. The only portion that occupies the 2nd level is the bonus room above a garage. Normally in the AutoCAD days, I would only show the portion that exists on the 2nd level and then outline the exterior of the building below. However, that isnt' quite as easy a task in Revit unless you want to ditch the parametric capabilities and draw detail lines (which I don't want to do). It also would require hiding the roofs at times since someone might not understand that its being show as cut.
In the past I have done a mix of things using the linework tool to outline the walls below, turn on the underlay for the level below, individually hiding unwanted elementsm etc.
So what have you guys been doing in these cases? See my attachment if my jibberish doesn't make sense. 🙂2nd floor plan.jpg
mp_thompson
A plan region sounds like your best bet:-
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
You can then form it around either the roof or just the romm/area you're cutting through (I'd do it for the roof).
Although there is some merit to leaving it as a true cut plan because you provide a better indication of the level compared to it's surroundings.
www.thompsonarchitecture.co.uk
chrisplyler
Interesting question. I suppose the answer depends on what you want to show exactly.
Just hide the roofs and set the lower floor as the underlay?
