How gray out a parameter
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
1479 Aufrufe, 5 Antworten
I have a family with two yes/no parameters. We obtains a value if one of two yes/no parameter is True.
Is there any to disallow or greyed out a field or parameter when I active a yes/no parameter.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
1=1
...sorry.  misread.  In order to gray it out, you need a formula. But, that would lock it down completely.  I imagine that's not what you want.
...Question: does the parameter actually drive a labeled dimension?
Nachricht 3 von 6
You can only grey it out permanently or not at all.
Here is another approach:
Nachricht 4 von 6
als Antwort auf: ToanDN
The parameter that drives a labeled dimmension is DISTANCE WIRE TO CELLING.
I would like the user can't type anything in the DESIREDDISTANCE WIRE TO CELLING field if the MAGNET OR HINGE parameter is active (True).
Thank you.
Nachricht 5 von 6
No can do.  You could create a text parameter below it that reads "DO NOT TOUCH DESIRED DISTANCE WIRE TO CEILING " when the MAGNET OR HINGE parameter is active (True). Smiley (zwinkernd)
Nachricht 6 von 6
als Antwort auf: barthbradley
Ok.
Thank you for helping me.
