So im trying to render a model built in Revit that i imported into Lumion. When rendering in Lumion if you render a material that is used in mulitple parts of the model it will change that material everywhere.
I am rendering carpets at the moment. To try and get around the problem above just duplicated the carpet material in Revit, eg i went into the family edited the structure then duplicated the material carpet. This did nothing Lumion is still changing all the carpets if edit the material on one of them ?
What is the best way to get around this? I mean i could just create all the carpets in revit with completely different materials associated to them eg brick, wood, plastic but this will get really messy?
Help please thanks
