Is there any ways you can select all model elements under one phasing or a filter to just select elements under a particular phasing? thank you.
The only thing i figured is that i could just set the View Property's Phasing Filter and only just work on there to avoid selecting Model elements not included in that particular phasing!
Using the the phase & phase filter under view properties is how I do it. If it's something you need to do often, you can create a selection filter for those elements which will not be dependent on the view properties.
