how do you safely remove the older revit 2016 program. I am currently using revit 2018 and so I dont need 2016 anymore.
How do you run a Run a Repair Install of Revit 2018? I think I damaged the program in the process of incorrectly trying to remove Revit 2016
I would leave it installed in case you need to do upgrades or legacy projects in that version.
it is better to have it than have to reinstall it when needed.
If you do any upgrades it is better to do them sequentially 16,17,18 and not skip versions.
if hard drive space is an issue and you are using the Autodesk Desktop app you can use that to remove it too.
your subscription allows (3) versions to be active (licensed) on your pc.
