How do you print a hyperlinked URL to PDF from Revit?
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
curtisridenour
641 Aufrufe, 6 Antworten
How would you print a hyperlink with a URL to a PDF from Revit?
I want to be able to click on a hyperlink in a PDF that would take me to a location on a local server or on the internet.
@RDAOU
6 ANTWORTEN 6
Nachricht 2 von 7
djforemandesign
als Antwort auf: curtisridenour
You should be able to create a Shared Family or Project parameter that is a type URL. Then fill in the desired URL in each family and create a custom tag using that parameter.
Doing a quick test of a Shared Project parameter of a type URL and printing a PDF I was able to click on the link in the tag.
Nachricht 3 von 7
curtisridenour
@djforemandesign  I tried this the other day and nothing seemed to work. Probably user error. Thank you.
Nachricht 4 von 7
curtisridenour
I figured out my user error. In BlueBeam, you need to have the hand selected instead of the pointer to click on the hyperlinks.
Nachricht 5 von 7
djforemandesign
Glad you were able to get it to work.
Nachricht 6 von 7
Is it possible to have the same functionality for the conventional pdf readers ?
Nachricht 7 von 7
What would you consider a conventional PDF reader?
