I'm trying to create this type of railing, with glass panels and clamps. But none of my solutions work.
First I tried the rail family that comes in German library with Revit.
The issue is that they made glass panels as balusters, so they're fixed width. If they don't fit to your particular case, it's pretty much useless (as far as I can tell).
Then I thought I'd create it as a curtain wall.
This sorta works on leveled railings. The issue with this one is that handrails don't clean up at joins, there is A LOT of manual work (setting grids, setting panels to empty ones, setting posts...), and most importantly it doesn't work on stairs. At all.
Then I thought I'd go the other way from the first solution. I created posts with clamps, and glass panels just as a profile.
The issues with this one is that glass panel is continuous, breaking the illusion on renders (oh well, I could live with this one). Corner posts due to the clamps sometimes work, sometimes don't, depending on the direction in which you draw the railing. And most importantly, it doesn't work on stairs. Panel protrudes up and post from run to landing is perceived as a "corner post" again resulting in clamps facing the wrong way.
How would you create this so that it works both on stairs and balconies, and so it doesn't take as long to model it as it would to actually build it in real life.
Attaching images of my attempts and a file with them.
Thanks in advance!
