two walls are on the same plane. how do you make the seam between these two walls disappear?
i tried to join them but didn't make the seam disappear.
any solution? please see the attachment for clarification.
Gelöst! Gehe zur Lösung
Gelöst von bin. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Make them the same material, either paint the edge or set external wrap. You might need to lower the lower wall and attach it again.
Use the Linework Tool on the Modify Tab with Invisible Line and select ALL the edges (probably 4).
how do you paint the edge? And what do you mean by exterinal wrapping?
So sorry for more questions...
What you need to do to make the line disappear:
1. flushed faces
2. same material
3. joined geometry
Of course Lineworks can hide the lines too.
