How do you make a room schedule with an embedded structural columns schedule that actually shows data
10 REPLIES 10
Message 1 of 11
MichaelWolff
611 Views, 10 Replies
Probably the office hours for ask the experts are over but this will wait till end of next month if need be.
Here goes: How do you make a room schedule with an embedded structural columns schedule that actually shows data. I want the room number (the one auto-maintained by Revit), its name and which structural colums are in it, of the columns I need the entry concerning their locations according to any grids that might be present.
I am on Revit 2019.2.6.
No, I do not want to program anything by myself. Dynamo is not a solution but a forum of its own.
Labels (3)
10 REPLIES 10
Message 2 of 11
in reply to: MichaelWolff
What if a structural column spanning more than one level thus crossing more than one room?  There is a reason they use column grids to locate structural columns.
Message 3 of 11
Yien_Chao
yes it's possible.
create a multicategory schedule. you will have access to family, type AND rooms. then just filter properly.
Message 4 of 11
MichaelWolff
It will pop up in every room it passes through, of course, but that is not the question. There is the possibility to embed a schedule of structural columns into a room schedule - only I cannot get it to work properly.
Message 5 of 11
MichaelWolff
Before anyone suggests it, I have tried shortening the columns so that they are each fully inside a room.
Message 6 of 11
MichaelWolff
@Yien_Chao Unfortunately your approach cannot access the structural columns' location parameter. What about the embedding of a structural columns schedule into a rooms schedule?
Message 7 of 11
Yien_Chao
@MichaelWolff
unfortunately, the "Column Location Mark" is not a parameter that can appear as such in a multicategory schedule or even a structure schedule.
Maybe the solution is a simple dynamo that retrieve information into a project parameter, then your multicategory schedule will have the location mark AND room?
here the solution in found.
hope it could help.
Message 8 of 11
MichaelWolff
@Yien_Chao I cannot get your dynamo script to run inside my revit 19 installation. Maybe you are using a more modern dynamo than what came with r19? I am sure you have better things to do anyway. Thank you for looking into this. When I marked your earlier (still dynamo free) entry as a solution that was because it gave way to this:
Make a multi-cat schedule (room number, room name, column type and comments) AND a structural columns schedule (with type, location and comments). Export the structural schedule to Google/Excel, copy the location values over to the comments, re-import the schedule into revit, now the multi-c schedule has room locations according to the columns. If rooms contain more than one column you even get a range where to find the room. I used DiRoots' brilliant SheetLink addin to achieve this but I suppose any spreadsheet exporter-importer will do.
If you fiddle with the grid names you may have to close and re-open the columns schedule to update it.
Message 9 of 11
Yien_Chao
@MichaelWolff  i just run the script in R19 and it works fine. dont use my Revit file, but only the dynamo in your project you've sent.
Message 10 of 11
MichaelWolff
2023-06-28 07_22_45-Window.pngI am sure the script is fine, but I would need our IT department to install dynamo 2 point something on my machine.
Message 11 of 11
Yien_Chao
ok, so here the code, just paste it in a Python node. Don't forget to add a parameter by instance to the columns, here :  "column position"
import clr
#add reference DocumentManager and Transaction manager
clr.AddReference("RevitServices")
#import RevitServices
from RevitServices.Persistence import DocumentManager
from RevitServices.Transactions import TransactionManager
#add reference and Import RevitAPI
clr.AddReference("RevitAPI")
#import Autodesk
from Autodesk.Revit.DB import *
doc = DocumentManager.Instance.CurrentDBDocument
collector= FilteredElementCollector (doc)
filter = ElementCategoryFilter(BuiltInCategory.OST_StructuralColumns)
columns = collector.WherePasses(filter).WhereElementIsNotElementType().ToElements()
#get location
loc = [i.get_Parameter(BuiltInParameter.COLUMN_LOCATION_MARK).AsString() for i in columns]
#starts transation
TransactionManager.Instance.EnsureInTransaction(doc)
for i,j in zip(columns,loc):
	i.LookupParameter("column position").Set(j)
#ends transaction
TransactionManager.Instance.TransactionTaskDone()
OUT = loc
Forma Design Contest
Technology Administrators
