How do you locate a server file path?
1 ANTWORT 1
Nachricht 1 von 2
DSATTESON9VUKX
277 Aufrufe, 1 Antwort
In one model we keep getting the "Central model has moved message..." which prevents project users from creating a local file.  If I create the central the other user is blocked and visa versa.  When this has happened in the past the server path or network mapping was altered.
How can I see the path between the two machines to confirm network mapping is the problem?
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: DSATTESON9VUKX
The error message should tell you where it is and what needs to be done.
