I cant create a dimension between two detail line circles.
Is there a way to do this? i want to be able to dimension from the center and also from edge to edge.
My current solution is to draw white lines and dimension from them. this is a two step process when it shouldn't be. ive attached an image showing my solution.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von SteveKStafford. Gehe zur Lösung
Turn on the center mark for each circle.
Steve Stafford
Turn on Center for the circles, place dim and drag it to the circle line.
No.
If I know I want the center mark visible I'll create one, turn on the center mark and then copy it to other locations...edit the diameter if necessary.
Steve Stafford
