How do I clean up this area? I'm not sure on the exact terminology but it is where the gable wall connects the the roof/soffit. As you can see this is still visible in my project which doesn't look all that great. I have two separate walls for the vertical/horizontal siding, and I wish for my upper wall to run from the bottom of the rafter plumb cut to the other, which is also the soffit height if that clarifies. Thanks
That's not the style I'm looking for, sorry for the ambiguity. I'm looking for something like this, and what commands I would use to create this.
This doesn't work, everytime I draw my gable wall this way and try to attach to doesn't work right. It has that issue where one side will attach to the roof but the other will not(it makes the wall into a right triangle)
If automatic attach is not working, you can always edit the profile of the wall to get what you are after.
@Anonymous : If you can't get it to attach properly, try splitting the gable wall down the middle and attaching each side. This works for me in situations such as yours.
