I'm creating kitchen cabinets, the upper ones. Since they're above the cut line, I want them to be dashed. So I draw symbolic lines in floor plan, set it to "Casework [projection]" subcategory, they go solid. It's OK, doesn't matter what they look in family editor, I'll just change it in project, under Object styles. Right? Wrong.
There is nothing under Casework category except "Hidden Lines". Family is under the correct category (Casework) and when I put those lines on "Hidden lines [projection]" category, changing them in project works fine when changing "Hidden lines" under Casework, in Object styles.
How do I change how "Casework [projection]" subcategory looks?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
In the Family editor (ie: edit the family)
Now under Casework you should see the above subcategories
Create an Overhead or Upper casework subcategory and assign it your upper casework linework, then change the 3d element to be invisible on plan/rcp. If you open an OOTB wall cabinet family you will it is setup similarly.
