How do I use a downloaded revit file from the manufacturer into a wall
26 ANTWORTEN 26
GELÖST
Nachricht 1 von 27
rickowilmath
2080 Aufrufe, 26 Antworten
I am trying to create a wall assembly that uses T1-11 and have downloaded the revit file from LP.
Now what?
26 ANTWORTEN 26
Nachricht 2 von 27
als Antwort auf: rickowilmath
Is it in a RVT file? Insert into your Project via Load as Group, or use Transfer Project Standards.
Nachricht 3 von 27
hmunsell
What is T1-11 (sounds like something from terminator...)? what is LP?
Howard Munsell
Nachricht 4 von 27
als Antwort auf: hmunsell
Nachricht 5 von 27
rickowilmath
T1-11 is a type of siding mainly used in residential. It looks like plywood only the surface has texture and
there are vertical grooves spaced approximately 8" apart.
LP is the name of a company that manufactures T1-11. They used to call themselves Louisiana Pacific but now it
is just LP
Nachricht 6 von 27
rickowilmath
Thanks Barthbradly, however LP created the file in a later version of Revit than mine (2016)
I wonder how many potential users they are screening out by only offering the file in the latest release.
I looked for earlier releases and didn't see anything. Is there any way to use this as it is?
Nachricht 7 von 27
hmunsell
we have had cases like this in my office, you can try to contact the sales department and ask if they have older versions available. the times i have asked they often do.
Howard Munsell
Nachricht 8 von 27
Looks like 2014 to me, but nevertheless, why don't you build your own walls to Manufacturer specifications?  There's nothing particularly unique about their Revit Walls.  They are just Basic Walls.
...looks like their Details are in DWG Format. You can import those into any version of Revit -- or open them with any version of AutoCAD.
Nachricht 9 von 27
Redrunner92
als Antwort auf: barthbradley
@barthbradley wrote:
... You can import those...
 You used the "I" word...!
Nachricht 10 von 27
rickowilmath
I am new to Revit and haven't created any wall families yet.
That may be the way to go.
Nachricht 11 von 27
Redrunner92
Walls are a good way to learn some fundamentals of how Revit works.
Concept #1: Revit uses layers in its core elements (walls, floors, roofs, ceilings).
Concept #2: Revit has many menus. Become familiar with where each is.
Concept #3: Revit uses materials. Explore how these can be applied to various elements because using them can seem quite complex.
Concept #4: Revit likes to drown new users with information (and options) overload. It's ok to take a short pause, swim above water so you can breathe again, then dive back in :welle:
Nachricht 12 von 27
als Antwort auf: Redrunner92
Yes; Import CAD.  What do you mean?
Nachricht 13 von 27
Redrunner92
Many people say link, don't import, CAD files. Do you treat CAD details as an exception?
Nachricht 14 von 27
rickowilmath
I tried importing it into Revit and got warnings about some elements being lost during the import
and that there were no elements visible in model space.
It seemed routine to import manufacturers files into Autocad....
Nachricht 15 von 27
Whoever said that is an idiot.
Nachricht 16 von 27
Redrunner92
Errors like those are part of why many people prefer the Link method over the Import method of bringing CAD files into Revit project files. Linking them keeps the CAD file as a single entity and makes them easily removed and brought back in as needed. Importing is essentially "stapling" the CAD file to the project file: it is essentially a Revit element after being imported, and as such is subject to Revit's housekeeping rules (links are subject to these too, but they are more easily removed from the Revit file). AutoCAD and Revit frequently enough don't play well together. But if you carefully keep track of imported CAD files, then importing them can be beneficial.
Nachricht 17 von 27
I would help to know what you tried to Import into the View.
Nachricht 18 von 27
P.S. Errors like that have nothing to do with whether you have Linked or Imported.
Nachricht 19 von 27
rickowilmath
I tried importing the .dwg file they had available. I was not sure where to bring it into Revit so I tried
the first floor view.
Nachricht 20 von 27
Try Linking it.
Kidding.
What happened when you inserted it into Plan View?
