I want to hide all the walls in a 3D view except a few selected ones. When I enter the Reveal Hidden Element mode, the option to Unhide by Element is greyed out. What do I do?
See UNHIDE CATEGORY on the Contextual Tab? Press it.
...then hide everything except that one Element via Hide in View by Element.
You probably want to figure out a filter rather than hiding the category. Is there something common about the ones you want to show or hide?
the ones I have to show are a different family than the ones I want to hide
So then set up a filter (or filters) to hide the types you don't want to see.
@abdullah48arch21 wrote:@barthbradley That would be too time-consuming. I have hundreds of walls
The Filters is the best way, you can have a Variable and use it to Filtered the Elements.
