I am bringing multiple 2D details into a Revit "Warehouse / Library" project. The details are coming from multiple projects (many amalgamated companies) so text styles and line names are different. I remember seeing (Long ago in Revit training) a dialogue box where I could chose text style or a line type on the left side and attach it some how to the right side under the line or text it was suppose to become. Ie Text 2.5 black => Black Arial 3/32" I thought it was under Import but I can not find it.
Gelöst! Gehe zur Lösung
Gelöst von denis_borodin. Gehe zur Lösung
I am selecting one line then "select all similar" and changing to line type desired. Same with text. There are over two hundred details from twenty different projects and multiple drafters. Now I am thinking a LISP routine.
pyRevit worked wonderfully. Most Lines are to standard. For the text I pick a text and use "Select all in Project" not "Select all in View". There are a few times when the text shifts out of place but those are corrected as they are found.
