How do I make the walls & detail in section view?
galkconst
galkconst
Community Visitor
Community Visitor
I have been missing with this for hours. I want everything to show in detail, not big thick lines. I tried multiple ideas from research but nothing is working? Please advice.
kadmonkee
typically the level of detail you want may vary, so i create a section view of the wall and add detail components to represent the materials.
your screen shot represents a building section with a variety of wall types, I would create a specific wall section of each wall type and then detail that view as needed.
the example image show a typical wall type (highlighted ) and all other materials are detail components applied within the constraints of the wall definition.
you can use the same approach in your screen capture.
try to do that as long as you know those wall types are final.
otherwise you are creating more work and time than you may want
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
RDAOU
@galkconst
You can start by setting view to Fine instead of coarse…then use a wall with is not Generic (ie: has some layers in it)
kadmonkee
another thing to look at is your level of detail
Fine Medium or Course at the bottom of your Revit window
thank you
