How do I make the stair supports attach?
5 ANTWORTEN 5
Nachricht 1 von 6
593 Aufrufe, 5 Antworten
I'm making a branching, curved staircase, (trying to make a grand staircase) and the stair supports from the landing don't attach to the ones on the stairs. How do I fix this? image attached.
5 ANTWORTEN 5
Nachricht 2 von 6
Redrunner92
als Antwort auf: Anonymous
How did you create this stair: by sketch?
If you post the project file we can test things out and see what solution(s) we can conjure.
Nachricht 3 von 6
Are you talking about the way the stringers are meeting? You'd probably have an easier go of it by doing it as separate stair flights and landing.  Three separate constructs.
Nachricht 4 von 6
als Antwort auf: Redrunner92
Nachricht 5 von 6
Can you explain what you want to do?  Maybe I misunderstood you.
…photos would help too.
Nachricht 6 von 6
als Antwort auf: barthbradley
I'm attempting to make a grand staircase, with the branching stairs curving, the issue is that the railings and the supports on the landing won't attach to the ones on the stairs. one side did at one point, but now neither of them will.
