How do I hide this unwanted lie in my exterior elevation view? this unwanted line was formed in my elevation because the line is showing because it's my "top of slab" and "bottom of exterior wall" line, but I have a base trim on my exterior wall that hides this seam. Please see the attachment for clarification.
Is there any transparency applied to the material (either applied to the element itself via right-click > Override Graphics in View > By Element, or via V/G menu?) If so, remove this transparency.
Has an override been applied to that line via the Linework tool? If so, restore it via the Linework tool to <By Category>.
If the line simply will not go away, use the Linework tool to apply the <Invisible Lines> category to this line.
Does this line still show up in Consistent Colors and Shaded visual styles? More information would be helpful.
