How do I hide previous revision clouds?
ABSFDrafting
ABSFDrafting
I need to hide the revision clouds from previous revision, but only on the sheets that were updated. The ones that remain on the older revision, I need to show the revision cloud. That's why setting the revision to "tag only" or "none" does not work.
Cheers
Mike.FORM
Unfortunately this is one of those things that Revit is not good at since revision clouds cannot be filtered (i.e. hide all revision clouds on sheet that are not the sheets most current revision).
For your situation you need to manually hide the revisions you do not want to see.
