I am a self-taught Revit user and still learning. I have this situation where I have a roof the also serves as the ceiling for part of the second floor and the attic. The problem is when I create these walls they jut through the roof and don't attach like the end/exterior walls do. How do I trim them at the underside of the roof trusses?
Select the walls, click Attach Top/base on ribbon, choose Top, pick the roof.
FWIW - since you are are still learning - you can also attach to Ref. Planes and Edit Profile of Wall manually. Just thought I'd throw that in. Happy Reviteering.
