How do I get Twinmotion to work in Revit 2023?
gbiallas
gbiallas
I'm running Revit 23.1.50.23 and trying to get Twinmotion to work. In the most recent Autodesk support post I can find, Revit 2023.1 should be using Twinmotion 2022.2.2.3 and the Datasmith Exporter 5.0.3. The Epic Games Launcher only goes back to Twinmotion 2023.2.4. I've tried this version. I've tried Twinmotion 2024.1.2 with the latest Datasmith exporter. Everything gives me the "Twinmotion is not installed" warning. How do I get Twinmotion to work in Revit 2023?
azad.Nanva
you don't need to Export to DataSmith..., you just need open the Twinmotion and Use Direct Links.
for run the correct twinmotion open Epic Game ,Twinmotion and Select Correct Version(Update if you need or Lunch) or make the Shortcut:
"C:\Program Files\Epic Games\Twinmotion2024.1\Twinmotion\Binaries\Win64\TwinmotionCookedEditor-Win64-Shipping.exe"
gbiallas
My apologies. I failed to watch your video before responding. Your instructions worked like a charm. For those watching at home, ignore the Open in Twinmotion button entirely.
