How do I fix my lineweights so that they are correct in that scale
6 ANTWORTEN 6
Nachricht 1 von 7
AidanHawkins
406 Aufrufe, 6 Antworten
I have inherited a revit file from a colleague, and for one of the floors the linewiehgts are much thicker than usual...
How do I fix this so that they are normal to the scale of the drawing
Thanks you guys are awesome
6 ANTWORTEN 6
Nachricht 2 von 7
rxi.gg
als Antwort auf: AidanHawkins
Please, check these links:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Revit-C...
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Nachricht 3 von 7
AidanHawkins
als Antwort auf: rxi.gg
yes I have checked both and the line weights and the object style line weights are exactly the same as the other levels ..
Nachricht 4 von 7
rxi.gg
can you upload the model to check it?
Nachricht 5 von 7
AidanHawkins
I cant share the model but here is screenshots of my problem
all the values for object styles and line weights are exactly identical on each of the floors.
Aidan
Nachricht 6 von 7
rxi.gg
They are so small to see anything!
Nachricht 7 von 7
AidanHawkins
Sorry hope this is better
