How do I extend a custom-made road marking line?
I came up drawing  a custom-made road marking line, to be exact it is identical to the taxiway centre line of an airport. Now as I load it into my project, I find that the dimension of the  line is fixed and I can't extend it to suit the need of the environment. What I can do is manually repeating many short lines to form a long line.
Please leave comment if you know how to do it. Thank you.
Linebased family?  Also make sure your dimension for it is an instance parameter and not type.
Line-Based Family "Length" Parameter is an Instance Parameter.  Cannot be changed either.  But, I'm with you, @Anonymous: OP needs only make "Length" in his Family an Instance Parameter.
