Hey there,
How do I create transparent mass as shown on the attached image? I've discovered it in Revit sample file.
Thanks in advance.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Select the massing and give it material. If you plan to copy multiple massing, I would parametrized it.
@nikitadoroshko7 wrote:Hey there,
Thanks in advance.
They look transparent in your screenshot. Are you talking about the Mass floors? You can add a transparency to the Material the Floors are using.
No, I am talking about actual mass in which mass floors are located, so they become visible. Looked in Visibility/Graphics overrides but didn’t find anything
It looks like the mass is visible. But turn on Mass Category under VGOs and/or turn on "Show Mass Form and Floors" on the Massing & Site Tab.
Massing is always set to turn off by default. This button will turn them on.
See my first post. You have to add material.
The default material for mass is already transparent unless you deliberately modify it.
