How do I create a window in this hole?
48 ANTWORTEN 48
GELÖST
Nachricht 1 von 49
l.yong1
2669 Aufrufe, 48 Antworten
Hi there,
I have created this hole with extrusion. Does anyone know how can I turn this into a glass window with frame?
Thanks for your help.
Please see attached screenshot.
48 ANTWORTEN 48
Nachricht 2 von 49
RDAOU
als Antwort auf: l.yong1
@l.yong1
Since you or someone led you down the path of modeling everything in-place!!! finish it off with in-place modeled elements
  1. Create/Place a non-embedded curtain wall (no mullions, and panel = basic wall Glass material)
  2. Cut the curtain wall with a void (the negative of that you cut the opening with)
  3. Sweep a profile around the edges
Nachricht 3 von 49
l.yong1
Hi RDaou,
Thank you for trying to help.
  1. Create/Place a non-embedded curtain wall (no mullions, and panel = basic wall Glass material) => with extrusion?
  3. Sweep a profile around the edges => how do I do this?
I love the picture you shown me. It would be great if you can guide me step by step how to achieve it.
Thank you:lächelndes_Gesicht_mit_Sonnenbrille:
Nachricht 4 von 49
How did you create the hole and what exactly is it cutting?
Sounds like you created the hole using an In-Place Modeled Void Extrusion and then used Cut Geometry tool to cut the Solid host (Wall by Face?) with the intersecting Void geometry.  If so, edit the In-Place Family that contains the Void and add to it the Solid Geometry (i.e. Extrusions, Sweeps, etc.) representing the Window Glass and Frame. Assign a Project material to these solid geometries through their "Material" Parameters, and then Finish and Close out of the In-Place Modeling Session.  Voila! A Window and Frame.
Nachricht 5 von 49
l.yong1
als Antwort auf: barthbradley
Hi Barth,
Any chance you can show me how to do those steps with pictures or diagrams?
Thank you
Nachricht 6 von 49
@l.yong1 wrote:
Hi Barth,
Thank you
You have already done it.  That is, you already created the In-Place Family that made the hole; right?  If so, just Edit the same family and add the Solid Geometry to it.
...Post your RVT.
Nachricht 7 von 49
l.yong1
Yes but it won't line up perfectly into the hole:neutrales_Gesicht:
Nachricht 8 von 49
Huh? Use the Pick Lines tool when sketching the Profiles for the Solid Geometry.
Can you just post your RVT?
Nachricht 9 von 49
l.yong1
Please give me 10 mins. I will show you what I have got so far. Thanks
Nachricht 10 von 49
l.yong1
Nachricht 11 von 49
l.yong1
As you could see from above pictures, the solid geometry does not fit into the hole nicely
Nachricht 12 von 49
Post your RVT as a Attachment to a reply post.
Nachricht 13 von 49
l.yong1
Hi, I was not able to attach revit file here. The file is too big. My building is a curved shape. I just need help with create windows and door on curved walls please.
Nachricht 14 von 49
If you cannot create a sweep for some reason, then take a look at the attached Revit file and screencast.
https://knowledge.autodesk.com/community/screencast/dbcb3830-62e5-478a-bbe1-8a1869579676
Nachricht 15 von 49
You don't need to post the entire thing. Just select the elements we're talking about (e.g. Wall, holes, etc.) and Group them. Then go to the Project Browser, right-click on the Model Group you just created and press "Save As" in the drop-down.  Then follow the prompts to save a copy of the Group to a separate RVT.  You can post that "Group" RVT here as an Attachment.  After doing the "Save-As", you can ungroup the group in your Project.
Nachricht 16 von 49
l.yong1
I just did. The file is still too big. Sorry:neutrales_Gesicht:
Nachricht 17 von 49
l.yong1
als Antwort auf: ToanDN
Thank you. I will try later. Will let you know if I get it resolved:leicht_lächelndes_Gesicht:
Nachricht 18 von 49
l.yong1
Please see attached rvt file. I just created a brand new file. Thanks
Nachricht 19 von 49
Like this?
Nachricht 20 von 49
l.yong1
Yes that is cool. How did you do that? Can you please show me step by step? Thanks
