I have this partial conic face:
I created a curtain system on the face and the V grid has a strange skew which I don't want. I am trying to make the V grid vertical.
which is what I get when I create a curtain system from an uncot conic face
I tried dividing the surface and setting a custom rotation for the V grid, guessing at a value that seemed to produce a close result. But I don't know how to use this divided surface to influence the shape of the curtain system.
Thanks for any input.
Gelöst! Gehe zur Lösung
Gelöst von ct_studio. Gehe zur Lösung
The solution is to create a slanted wall using a circular sketch curve.
red using Rhino
Green using Revit
Interestingly i can get an irregular border in one place but can't replicate this on the other edge.
I was able to do this by using an additional "helper" wall that i assign to an invisible workset.
Here's the original original intended result.
Create a mass form based on two curves for top and bottom then create a wall by face.
