How do I connect the piping?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
aoki.takehiro.01
205 Aufrufe, 2 Antworten
Attempted to trim straight piping but received the following message.
The route pattern failed because the default fitting type was not specified or a fitting was not found in the project. Please make sure the fittings are loaded into the project and try again."
What is the best way to deal with this?
Note that this assumes that the piping family was created after importing the piping family using the construction template.
Translated with www.DeepL.com/Translator (free version)
2 ANTWORTEN 2
Nachricht 2 von 3
rxi.gg
als Antwort auf: aoki.takehiro.01
Be sure if your pipe has the pipe fittings configured. You can see it in type properties of the pipe.
If your problem persists, please upload an screenshot or the model to check it.
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Nachricht 3 von 3
Thanks for letting me know!
I have successfully completed the project.
