When I import a consultant's CAD file into my Revit model I am not able to change all of the line's color and weight in Object styles because some of the lines in the CAD file are set to Style By Object and not Style By Layer/Level.
How do I set all of the layers in the CAD file to Style by Layer? All of the parameters in CAD are set to Bylayer. See below for screenshots. Thanks for the help.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
In AutoCAD use the command CHANGE. Type ALL. Choose Properties>COLOR>BYLAYER
Unfortunately if the block has override color, it won't change it.
