I'm looking to change key binds,
Usually you use the middle mouse button to pan and orbit an object in a 3D view, being that my middle mouse button is broken i was wondering if someone would be able to help me or point me in the right direction for context i want to be able top pres the "v" key and be able to pan and orbit.
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Not sure if you are aware of the Navigation Bar?
https://help.autodesk.com/view/RVT/2021/ENU/?guid=GUID-DA9ECDE0-604F-4B23-A8AB-CD67125FB6B0
Hope that helps, Cheers
Kunal Tuljaram Gaidhankar
There is no option/settings for that in Revit.
The key mapping has to be done via the driver of the mouse you are using. Some of them support button customization and some even have preset dialogues ... Example: ones I have used Logitech G Seriers and 3Dconnexion
perfect thank you ill give this a try in icue. greatly appreciate your time.
i appreciate your reply
yes i am aware of the navigation bar but have never used it as i found it very awkward. thank you non the less for your reply it is greatly appreciated
